Fuel Regulator Problem
Old Mar 18, 2002 | 03:00 PM
StocRoc's Avatar
I need to lower my fuel pressure some more, but the screw for the regulator is hitting the bottom of the plenum so I can't back it out anymore. What should I do?? Can I just take the screw out all the way and put a shorter one in, or will this screw something up?? Thanks
Old Mar 18, 2002 | 04:06 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
I believe putting in a shorter one will be fine.
Old Mar 18, 2002 | 09:34 PM
StocRoc's Avatar
can I leave the regulator bolted down? or does it need to come off?? Thanks
Old Mar 18, 2002 | 11:16 PM
Vader's Avatar
You can leave the regulator bolted in , but the plenum will have to be removed or at least taken loose to allow room to replace the screw.
Holley AFPR?
Old Mar 19, 2002 | 12:13 AM
StocRoc's Avatar
no it's made by crane cams
so it wont screw anything up if i take the screw completely out ?
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
