Is there a way to bypass the a/c?
Old Mar 19, 2002 | 06:27 PM
2clean's Avatar
my a/c locked up and it chewed the hell out of my belt. i tryed to run a shorter belt and bypass the a/c but the belt isnt tight enough. does anyone know of a way to do this without having to replace the whole a/c. or does anyone make a a/c eliminator for an 89 iroc z?? thanks
Old Mar 19, 2002 | 06:39 PM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
Re: Is there a way to bypass the a/c?
Do a search here for 'ac delete bracket'. You get about 20 hits with part numbers. Never seen one but have read about them here.
On my '88 serp. belt setup I seen no way of eliminating the ac without the delete bracket or changing everything to something else unless maybe I still have the air pump, which I don't.
Good luck.
Old Mar 19, 2002 | 11:40 PM
Swapmaster's Avatar
Have a new bearing put in the clutch. Should run about 100.00
They will not even have to take the compressor off the car.
$750 L98
Feb 1, 2025 02:25 PM
jrdturbo
Mar 31, 2016 02:58 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
