Identify Injectors
Old Mar 20, 2002 | 09:07 AM
Ray Burrows's Avatar
Identify Injectors
I am curious if any one can identify the injectors by the GM part #. Have a page that shows Bosch, Nippon Denso and some AC but not these numbers. First is 17120683 that was in LT! manifold from 94 Impala SS. Second is 17087325 also in a LT1 manifold but source unknown. Appreciate your help...Ray
Old Mar 20, 2002 | 10:04 AM
Vader's Avatar
Ray,
I'm not sure on the part number, but I'll check mine when I get a chance. Momma's '94 Impala has the OEM Lucas-CAV injectors (flowed by Cruizin' Performance of course) and they are reportedly rated at 3.64 cc/S, or about 22 lb/hr. @ 43.5 PSIG.
Old Mar 20, 2002 | 10:29 AM
IROCKER's Avatar
I was gonna say perhaps contact Rich at Cruzin directly and he should be able to easily identify them.
Old Mar 20, 2002 | 10:30 AM
Vader's Avatar
Ray,
Strike that. I went out and checked for a part number. They are NOT Lucas-CAV injectors, but are Rochester. I remember having talked to Rich at Cruizin' about them and I was afraid they were relabelled Lucas units, but they are not.
Unfortunately, as easy as it is to access the injectors on an LT1, I could not find a part number on them anywhere, despite the flashlight and inspection mirror. Just the "R-P" symbol near the electrical connector. When I removed the connectors, I didn't see a part number on those either.
Sorry if I mislead you earlier.
Old Mar 20, 2002 | 12:15 PM
Shadow's Avatar
Car: 88 GTA Notchback WS6
Engine: 350 with a SuperRam
Ray,
The first number you listed (17120683) is from a L99 4.3L engine.
The second number (17087325) is from a LT1 5.7L engine.
Jeff, I'm going to have to send you a new pair of glasses. The part number on your injectors is 17095004.
Shadow
Old Mar 20, 2002 | 10:03 PM
BlazinOR's Avatar
Re: Identify Injectors
Here are two sites to cross reference any injectors -
http://iroc.fbody.com/injectors.html
http://chevythunder.com/index.htm
Old Mar 20, 2002 | 11:06 PM
Swapmaster's Avatar
Cool.
Old Mar 21, 2002 | 10:45 AM
Vader's Avatar
Originally posted by Shadow
...Jeff, I'm going to have to send you a new pair of glasses. The part number on your injectors is 17095004.
Shadow,
I had a feeling you might have a small archive of data on some of those injectors. I must need new glasses - I even peeled off the markers I installed to identify the locations of the injectors, spun them around a bit, and saw nothing. "The Force" just ain't what it used to be...
Old Mar 21, 2002 | 11:01 AM
Shadow's Avatar
Vadar, Don't feel bad......even with my bifocals, I have a hard time reading the numbers on some of the injectors. I guess it's just one of those "age" things.
Shadow
Old Mar 22, 2002 | 01:54 PM
Thanks for responding---Ray
92-Formula
Dec 12, 2015 10:34 PM
Linson
Sep 21, 2015 01:08 PM
abrilnelson89
Sep 17, 2015 10:41 AM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
