stock fuel pressure setting
Old Mar 24, 2002 | 09:42 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
i want to convert my vette back to stock to see what kind of times it will run. in a post in the street racing board, someone was talking about a stock 5speed fox-body Mustang that was running 12s with just gears, converter, suspension upgrades, and slicks. i want to try that. anyway, what is the factory fuel pressure setting so i can set my adjustable unit to that? thanks in advance
Old Mar 25, 2002 | 12:04 AM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
43 PSI at idle with stock injectors.
Old Mar 25, 2002 | 01:05 AM
u r sofa king we tah did's Avatar
38 at idle, 42-43 with the vacuum line removed
Old Mar 25, 2002 | 07:05 AM
89BlueTA's Avatar
How can it be a "stock" car with gears, convertor, slicks and suspension mods. That does not sound very stock to me.
And those 5.0 mustangs like a lot more gear than our TPI cars do, I do not think you would get the same result with all that gear and convertor.
Old Mar 25, 2002 | 05:38 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
the engine was completely stock, right down to the paper filter. he modified the trans, suspention, and tires to see the real potential of the motor. and about the gears, my vette has the base 2.59s. i was planning on upping that to 3.45s. that should provide a pretty good increase in acceleration.
MustangBeater20
Oct 29, 2022 09:20 PM
specialized
Jun 18, 2022 09:26 AM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
Kaweh
Aug 9, 2015 02:54 PM
