anyone running advanced timing?
Old Mar 25, 2002 | 06:24 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
i was wondering what kind of results you guys had with bumping the timing from its initial 6* setting. i bumped mine to 9*, and added several other mods, and my car only picked up about 0.05 in the quarter (best out of 3 runs). GMHTP did a drag test with a stock GTA a few years ago, and their times actually went down with advanced timing (they blamed the lack of ET on the fresh glue the track officials had just laid down), however, this lack of performance seems to be happening to my vette also. just wondering your opinions and theories
Old Mar 25, 2002 | 07:27 PM
89BlueTA's Avatar
I run about 12-13 deg of timing. I always run 93 octane, with the knock sensor disabled.
nick
Old Mar 26, 2002 | 10:44 AM
mtccl's Avatar
I recently had mine set as high as 12* after installing new intake gaskets and porting/polishing the runners, but backed off to 9* after some pinging and valve lash. Definitely only run 93 octane. I would not disable the knock sensor.
Old Mar 26, 2002 | 12:18 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
every day running 11* BTDC, no problems. Also improvment at the track of .2 with timing only.
Old Mar 26, 2002 | 02:05 PM
87transam5.7tpi's Avatar
mine is 6deg advanced, it retards it at times(whenits like 200deg) but I notice a big difference when I runn 91 octance compared to 89, no retarding.
Old Mar 26, 2002 | 02:13 PM
85transamtpi's Avatar
I kept the '85 at around 9*. Any higher and I would get knock retard. Any lower is a performance loss at the track. I always ran 93 octane (even when it was $2.25 last summer).
This is something that is best to play with at the track.
-Doug
Old Mar 26, 2002 | 02:39 PM
also I forgot to say I've heard this helps and that it doesn't but my car runs the 1/4 faster than the other cars with pretty mucht the same mods and no advance in timing. maybe its just a fluke, maybe not :-) also my enging only has about 25,000miles on it. so that may make a difference too.
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86IROC112
Aug 17, 2015 02:00 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Thirim
Aug 9, 2015 06:19 PM
