Oil Filter leaks after removing cooler?
Old Mar 28, 2002 | 10:51 PM
onetontj's Avatar
The 350 TPI in my Jeep came with a remote oil cooler. I pulled it off and put the filter directly on to the block. When I started the motor it leaked a whole bunch of oil. Tried a different filter and same thing happened. I put the cooler back on and it doesn't leak...there must be some type of sealing device that goes on the block if your not using the cooler...can someone help out, maybe a part #?
Old Mar 29, 2002 | 11:27 AM
onetontj's Avatar
Was hoping for some help.
Is the oil filter mounting pad on the oil cooler equipped blocks different from the regular mounting pad? If so I'll just swap it out.
CJ
Old Mar 29, 2002 | 09:41 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
The engines with oil coolers use special bolts to retain the oil filter base and these special bolts also space out the cooler so it locks to the block. When you remove the cooler you must replace the special bolts with standard bolts that do not space out the cooler, otherwise it will leak. Replace the bolts and your problem will be solved.
Old Mar 30, 2002 | 11:04 AM
onetontj's Avatar
Yeah, I did that yesterday and it fixed the problem...thanks a lot!
CJ
maroe624
Apr 16, 2017 08:29 AM
Derick15
Sep 17, 2016 05:28 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
