cold start problems
Old Mar 29, 2002 | 10:33 PM
92superram's Avatar
cold start problems
When I start my car after it sits for a ling time, it doesn't want to start or idle. After the engine is over 120 degrees, it runs great. When it is already warm and i try to start it, it won't start the first try, but it starts right up on the second try. Anybody else with superram having this problem? I have a custom FastChip. What can i do to help with this starting problem.(I am sick of having to let my fuel injected car warm up for 5 minutes before driving)
Old Mar 29, 2002 | 11:10 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
It may be your aftermarket chip. Try putting your stock one in just to see if that fix’s the start problem.
Old Mar 30, 2002 | 04:18 PM
92superram's Avatar
the problem was worse with the stock chip.
Old Mar 31, 2002 | 01:14 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Check for vacuum leaks. Set your minimum idle air. Calibrate your TPS sensor. Check your fuel pressure. Check your coolant temp sensor with an ohmmeter to see if it is reading within the range it should be.
92camaroJoe
Jul 29, 2023 07:57 PM
Wade787b
Sep 29, 2015 01:15 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
