TPI sensor
Old Apr 5, 2002 | 12:08 AM
kenny89's Avatar
TPI sensor
i have a 89 iroc and my MAT is not pluged in on the bottom of the plenum i forgot to d it when i put it together can i leave it undone or does it hava to be pluged in? also the car will ot idle after it has warmed up can that be caused by the sensor not being pluged in?
Old Apr 5, 2002 | 12:27 AM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
You need to plug that sensor in.
Once in closed loop mode the ECM will throw a code if not and it may go into Limp Home mode.
Old Apr 5, 2002 | 09:10 AM
IROCKER's Avatar
If you're really crafty you might be able to plug it in with some needle nose pliers...not sure though. When I put everything back together I triple checked all the connections...I was paranoid about having to undo everything again.
Old Apr 7, 2002 | 11:09 PM
Agent-Z28's Avatar
I did the same thing when I rebuilt my engine. I got it in but it was a major biiiiiiiiiiiiiiiiiiiitch. You do need it
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
