406 ???
Old Apr 6, 2002 | 08:52 PM
bobs89irocz's Avatar
406 ???
I am starting to think of a new combo, I see alot of you guys are running a 406. What are the advantages of a 406? I have a 386 stroker in another 89 iroc but this motor will be for a different car. Should i go with another 383 or should i go with a 406? Also how do you get a 406? (400 bored?) And does 350 heads bold onto the block with any problems? Thanks guys
Old Apr 7, 2002 | 12:29 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Sorry I can't help you. But I would also like to know.
(I think its a 400 bored .030 over) But what do I know?
Old Apr 7, 2002 | 01:57 PM
rhuarc30's Avatar
There's no replacement for displacement . That's the biggest advantage of the 406. The long stroke also helps build torque. Advantages over a 383 are aren't huge, but over a 350 substantial. And yes a 406 is a 400 bored .30 over.
Old Apr 7, 2002 | 03:40 PM
Thanks guys for your help, but does the tpi setup fit on a 400. Is the head bolt angles the same as it is on a 350? thanks alot guys for your help. Thanks
BObby
C409
Sep 23, 2015 04:30 PM
mddaniel
Sep 8, 2015 05:16 PM
trevor1010
Aug 26, 2015 02:41 PM
trevor1010
Aug 24, 2015 08:34 PM
trevor1010
Aug 24, 2015 11:29 AM
