Rear End Identification
Old Apr 24, 2002 | 10:46 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
Im looking for the gear ratio for this 84 Z28 Camaro differential. The numbers that was located on the passenger side axle are:
6fb 0339
under the differential:
22522676
Thanks: DTL504
(84 Z28 Camaro, 2 Seater Convertible w/
283 bored 80 over,flat top pistons, 202/160 Camel Hump Heads 64cc (3782461), Edelbrock RPM Maniford, Holley 670 Avenger Carb, 700R4 Trans).
Old Apr 25, 2002 | 12:01 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
3.42 posi
Old Apr 27, 2002 | 08:10 PM
OneHotV6's Avatar
Car: 2005 Ford Mustang GT
Engine: 4.6 Litre V8
Transmission: Auto w/OD
I have a rear also that I want to figure out what it is... it came out of an '89 RS. The number on the bottom of the differential also has 22522676 on it, is it a 3.42 posi also? There isn't any #'s on the axle itself as far as I can tell.
Thanks!
Old Apr 27, 2002 | 08:18 PM
AlkyIROC's Avatar
Car: 87 IROC L98
You need to get the axle code. It's on the front of the passenger side tube. It's usually filled with rust, dirt etc. A wire brush is usually needed to clean the tube to see the code.
If the rear isn't in the car yet then just pull the cover and count the teeth.
If the 89 RS had a V6 then it's a 3.42 without posi. If it had a V8 then it had 3.08 with a manual transmission and 2.73 with an automatic transmission both without posi.
Old Apr 28, 2002 | 05:49 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
he did find the stamping code, its DTL
Old Apr 28, 2002 | 09:12 PM
DTL504's Avatar
Its there on the passenger side axle, you just have to remove all the rust. I was thinking the same until it finally broke thru and I seen the numbers. Can anyone tell me where I can find the specification chart that identify this rear end as a posi with 3.42
Thanks: DTL504
Old Apr 28, 2002 | 11:29 PM
OneHotV6's Avatar
The only chart I know of and got some info on is at https://www.thirdgen.org/newdesign/tech/techdb.shtml
Old Apr 29, 2002 | 04:36 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
My 89 Rs Came stock with a 2.8 AND POSI GEARS.......Either that or my rear end has welded its self together. Both tires light up when doing a burn-out.
Old Apr 30, 2002 | 04:55 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Actually, the code shouldn't be DLT504, it should be 6fb 0339 . If you had a manual trans in that car, you'd have a 3.73/posi/disc rear... did it come with a manual originally?
Either way, if it's a posi, it'll be an Eaton gov-lock... search this message board for gov-lock for some not-too-good news. (I joined the ranks of guys whose gov-lock died... not too long after putting a 3.73/posi/disc rear from an '84 T/A into my '86.)
Old Apr 30, 2002 | 08:25 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
good point, im thinking of truck stamping codes, they are all letters unliek these cars, wierd..
Old May 1, 2002 | 05:39 AM
DTL504's Avatar
The code is not DTL504, that is my screen name the code on the axle was 6FB 0339, just in case anyone was confused. I have yet to see this code on any specification chart, but a look on internet sites tell me its has a 3:42 POSI for that year, engine, and 700R4 Automatic Transmission. I would like to see the axle code chart of 6FB 0339 identifing this rear end if one is out there. I was under the impression that this was a limited slip rear end and the other axle will kick in after a shift in weight.
Thanks: DTL504
Old May 1, 2002 | 10:54 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The gov-lock used a spinning weight to engage both axleshafts; and it would chip the teeth of the spider gears over time...
Ever change the rear fluid? Might as well drop the rear cover and count teeth; buy a gasket, some 80w90, and a bottle of the $15 posi additive from GM, and you'll know for sure.
Old May 11, 2002 | 02:46 PM
DTL504's Avatar
today I took the cover off to verify the true gear ratio and I was 41 big gear and 11 small gear, came back to the computer and found the web page that list gear ratio and its a 3.73. Could not believe it so I went back outside to verify what I had already counted three times and yes it is correct they have 3.73 gears in the bugger. I just dont know how well they are going to work with this combo that I have put together. I really just putting a street rod together and dont have plans on going on the track. However one thing that I notice that when I turn either axle the differential do not spin. I would have thought that if I turned the axle I would. The little gears in the inside do however spin and the axle are not locking on to the spinning gears. Do it require a certain amount of torque before they will spin and lock. Also how do you think this combo will work with these gears, will be street driven, however not everyday
Old May 13, 2002 | 08:42 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
spider gears are splined onto the shaft ends
Old May 13, 2002 | 09:09 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hey,
Funny I'm thinking of using a 84 Z28 rear end as well, cuz its a 3.73 and my 9 bolt is only a 3.27..
Though, i don't think its a POSI..
Wnyone know the size of the ring gear on these?? I need a spool for the track.
-- Joe
Old May 13, 2002 | 10:34 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
7.5" = chevy rear
7.65"= aussy rear(borg)
Old Jun 2, 2008 | 05:45 PM
joe20smoke's Avatar
Re: Rear End Identification
I just bought a rear end with disc brakes, and trying to find out what it is the paasenger axle said 6hs c188 2, and on the bottom it said GM N 22522676. What is this rear end can any1 help me please.
Old Jun 23, 2009 | 12:58 PM
halostryker's Avatar
Car: 84 Camaro z28
Engine: 305. LE9
Transmission: 700-R4
Axle/Gears: 3.42:1 Locking
just go to this site it give you all the information you need for an 84 camaro
http://www.iroczone.com/specs/camaro/camaro84.html
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
