help with freshly rebuilt trans
Old Apr 30, 2002 | 01:57 AM
Garett92Z's Avatar
Hello,
I had my trans. just rebuilt with corvette servo, transgo shift kit, 2400 rpm Heavy duty stall converter. engine was rebuilt as well.
anhow. two questions.
1: I would like to protect my investment on the trans. with a good trans. cooler... any recommendations? I am on a budget so something decent pricewise.
2. Sometimes when I start in 1st (megashifter) and shift to 2nd it won't shift into 2nd right away... is this normal? other times (most times I should say) when I put it in 2nd it goes RIGHt into second and sometimes chirps!
3. I know, i know... hehe. well when I am in 2nd gear say and I floor it around 4000 rpm or something like that I feel a bit of a power surge.... like the engine picks up a lot more which is strange. This have something to do with torque converter?
Garett
PS: one more.. please! i'm new to this stuff. With a highstall converter 2400rpm would you actually FEEL the power at 2400rpm kicking-in? like a slight difference in power between 22 00rpm and 2 500rpm? would that possibly happen?
Old May 1, 2002 | 01:50 AM
Garett92Z's Avatar
why does nobody ever help me when I post? I help others with my knowledge (mainly on appearance board)
gc
Old May 1, 2002 | 05:30 AM
Pro Built Automatics's Avatar
I carry the largest Hayden trans cooler (26,000 lbs. GVW rating) model #1405, it sells for $45.00. When you shift into 2nd, is it at a lower rpm than the WOT shift point if left in drive? If you are trying to do that, (shift at a lower shift point than the WOT governor shift point) it will not happen. If you shift the lever, and it shifts right away (1-2), and it is at the same rpm?, then check the fluid level, if it is low, this might account for the inconsistencies.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reddeath210
Oct 6, 2015 08:20 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
