Problem with gear swap.
Old May 1, 2002 | 08:24 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Any one had a problem doing a gear swap in an '89 10 bolt rear,
I was told by SLP that all late 80's 10 bolt rears had 28 spline axles so I bought a posi and gears for 28 spline axles, when we took the car apart, we found 26 spline axles.
Is this unique to the 89's, or did i get that one in a million odd ball car.
Oh yeah, the mechanic also said the ring gear was too big and was doubtful that it would fit inside the housing.
Anyone else ever run into this?
Thanks.
Old May 1, 2002 | 11:33 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
You don't have the BW 9 bolt do you?
I know that the 7.5" and the 7.625" ring gears will fit on the same carrier. A friend of mine put a 7.5" ring gear on an OEM 7.625" carrier. I think 89 was one of those "in-between" years where some had the 26 spline and some had the 28...at least it was for the M-Body.
Old May 1, 2002 | 11:44 PM
Its deffinatly a 10 bolt w/ drum brakes.
The mechanic looked in the mittchel guide for the part numbers,
86 to 88 were all the same, 90 to 92 were all the same 89 was the only one that didn't cross over to other years.
Old May 2, 2002 | 12:15 AM
vjo90RS8's Avatar
Car: 2002 Z28
89 was the cross over year, only some of the cars that year got the 28 spline rear.
junkcltr
Aug 2, 2019 11:12 PM
InfinityShade
Aug 22, 2015 08:00 PM
jharrison5
Aug 19, 2015 05:53 PM
sreZ28
Aug 14, 2015 07:48 PM
