just installed speedo gears, and now have problems
Old May 4, 2002 | 11:11 PM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
i just installed some speedogears and i installed the clip that holds the gear on the shaft in the rear hole. everything was fine until i hit second gear. then i heard a metal sound. but everything else was fine. speedo read right now. then on the freeway i floored it and my speedo increased a bit then it just went to zero. and i now have a check engine light. do i need to put the clip in the first hole. i believe i have this light cuz my speedo is not working now. am i right?
Old May 5, 2002 | 09:35 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Yup, you have a code 24...vehicle speed sensor. Most likely something happened with your speedo drive gear as you suspect.
You installed the metal clip correct. The drive gear might have cracked when you put it on there and then decided to let go as you were driving.
Old May 5, 2002 | 11:05 AM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
i had some instructions and it said ot put it in the front hole.
hectre13
Dec 11, 2023 08:14 AM
rocn7roc
Sep 21, 2021 02:16 PM
hectre13
Aug 26, 2015 08:17 AM
dhonda200
Aug 11, 2015 11:50 PM
beachrodder
Aug 7, 2015 04:27 PM
