Ring Gear Sizing...
Old May 8, 2002 | 08:22 AM
black88ta's Avatar
Car: 1988 GTA
Axle/Gears: 3.27:1
Ring Gear Sizing...
I am in desperate need of some help this morning. When I bought my T/A, my friend who owned it told me that the rear would need to be re-built. I have evaluated the situation, and it seems that the rear vibrates because there is no fluid in the diff. It looks like the front pinion seal has been leaking for quite some time, and all of the fluid has drained out.
I am going to pull the cover off tonight, and try to see what is salvageable from the rear. My fear is that I am going to have to replace the front pinion bearing, and both axle bearings, as well as all three seals. I just called Autozone this morning, and the have some of the bearings, but they need to know what size ring gear I have. Is there anyway to find that out, without physically taking the rear diff. cover off and measuring?
Once again, it is a 1988 T/A, with a manual 5-speed. It seems to be an open rear, as I have not been able to spin both rear tires at the same time. Any help would be appreciated. I do plan on doing this tonight, and I am currently driving it everyday, so I would not be able to let it sit overnight all torn apart.
Old May 8, 2002 | 11:28 AM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Count the bolts on the rear cover. 10 is a 7.625 10 bolt ring gear, 9 is the heavy duty 7.75 ring gear aka 9 bolt rear.
Miles
www.9bolt.com
F-body driver
Mar 6, 2023 11:44 AM
db057
Apr 28, 2019 07:45 AM
Fronzizzle
Sep 8, 2015 12:10 PM
BOOT77
Sep 5, 2015 03:55 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
