Elect to Manual Speedo
Old May 8, 2002 | 01:27 PM
Wolfpack's Avatar
Car: 86 Iroc
Is it possible to change an electric speedo 700r4 to a manual speedo with out tearing the whole trans apart? One guy at the GM place said that all i needed was a new Tail shaft housing and the proper gears...another said that he thought the relucter ring for the electric speedo was pressed on and he didn't know if it would be possible to go to a manual speedo....the trans is kinda junk atm and im goin to put a new one in somtime...but i need a speedo...tickets suck
Old May 8, 2002 | 08:58 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Re: Elect to Manual Speedo
That depends on what the trans came out of. My GTA uses the same drive gear as a manual does. Take the sensor out and look at it. If it has a gear on it, all you have to do is change the adapter. If it has just a magnet, you have to have the gear pulled off, and replaced.
Old May 8, 2002 | 09:07 PM
Wolfpack's Avatar
Car: 86 Iroc
Ok so is the sensor inside the tailshaft housing? I really know jack bout trans..so any info would help...thanks again
Old May 8, 2002 | 09:48 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
The sensor is on the left side of the trans, on the tail housing. It will have some wires plugged into it. It is held into the side of the trans with a bracket and bolt. [ 10 mm wrench] Dought if you can see the #s on it without removing it. When you take it out you'll lose some trany fluid, so have some on hand.
Old May 8, 2002 | 11:02 PM
Wolfpack's Avatar
Car: 86 Iroc
So the sensor is on the left side of the tailhousing??? were the cable from the speedo comes down too?? Well crap i just knew there was somthing wrong there...i have looked at that and guess what...nothing but an oval hole there no wires no nothing...just the tailhousing with that oval hole(speedo cable is round) well looks like I gotta find out what im missing and fix it...crap..any ideas? THanks again
Old May 8, 2002 | 11:16 PM
Wolfpack's Avatar
Car: 86 Iroc
BTW apperently this car is juried rigged...so i have no idea what this trans came out of...but im sure its not the original...car had 2 tv dent cables when i got it(lose one is gone now) so im kinda at a loss as to how to fix this prob..like i said i no nothing about transmissions at all...thanks again
Falcon50
Aug 22, 2020 03:26 PM
Fireslash
Apr 11, 2016 06:43 PM
bjpotter
Oct 4, 2015 07:48 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
