Someone explain this its weird!!!
Old May 9, 2002 | 10:02 PM
88greyiroc's Avatar
i was at a stop light and my car was in drive i went to leave and it felt like the car was in neutral i tried O/D and D but notihing i put the car in part and then back in O/d and it works great now.
Old May 10, 2002 | 07:51 AM
88greyiroc's Avatar
Can't anyone explain this it must of happened to someone??the car is working perfect now i would really like to know what that was.
Old May 10, 2002 | 05:35 PM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
O.K. This is only my experience with automatic cars:
When you stopped your car, all the fluid went at front of the pan and the oil pump was without oil. Some seconds after, the fluid went at original level into the pan, and your car had movement.
My recommendation:
1- Fill fluid at FULL mark (no less, no "add").
2- Wait the next days at normal driving.
If nothing happens = your tranny is good.
If the same event repeat 3 or 4 times = (sorry) prepare for overhaul.
Regards,
Denis V.
Old May 10, 2002 | 06:42 PM
ronterry's Avatar
Car: '94 Corvette
Denis has point.
I used to have my trannie drop out of gear in hard turns, and hard braking cause of a low oil levels. It's was how I knew to check the oil level.
Ron
F-body-fan
May 4, 2026 09:42 AM
Pac J
May 17, 2020 10:44 AM
Ed1LE
Sep 30, 2018 09:14 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
