Trans Fluid for '85 T-5
Old May 8, 2002 | 08:36 PM
DiecastZ28's Avatar
What do I put in it. My father and I dropped the tranny during the winter, and put new seals in it. We drained the oil and put in 10w-30... According to him that is what the serive manual recommened. Now my tranny has an annoying whinning. Is there another kind of fluid that you are suppose to put into it? Please help me out.
Old May 8, 2002 | 09:16 PM
YenkoZ28's Avatar
Car: 1991 Z28
Engine: 305 TPI under 14 psi
Transmission: aftermarket T56
Axle/Gears: Moser 12 bolt 3.08 gears
I can't remeber what the 85 T-5 calls for but some years got dexron III auto trany fluid and other years call for manual tranny fluid. I would say that 10-30 motor oil if thats what you put in it is not the right stuff and get it out quickly. I personally use redline MTL in my WC T-5 and it originally had dexron III in it. I have read that redline MTL really strengthened up the tranny and made quite a diff. So far I have had no strange sounds or whines from my T-5 with redline MTL. My father also uses it in his 87 Iroc and my sister uses it in her 83 Z28 T-5. Hope this helps.
Old May 8, 2002 | 09:25 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
i run atf in my 84 Z28, hope that helps
Old May 9, 2002 | 06:41 AM
Intercepter's Avatar
In the B&W T5 service manual it states Dexron II ATF.
Old May 9, 2002 | 07:32 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
WC vs. Non WC is a big consideration here. Without a doubt all of the WCs call for ATF, but the non WCs seem to vary, and even GM couldn't make up their mind. Their specifications seemed to change from year to year.
Both of my 86 2.8s had ATF in the transmissions, but from what I recall from reading here, the non WCs used gear oil in order to make the synchros function properly. The WCs used a tighter tolerance synchro, thus necessitating the thinner ATF.
BUT, (there's always a but ), the input shaft bearing doesn't get a lot of oil way up in front, and I think the gear oil made that situation even worse. With the ATF, enough splashed up there and kept it lubed.
So, basically to answer your question, I don't friggin know.
Old May 9, 2002 | 08:45 AM
Lounge Lizard 6's Avatar
My '84 Helms call for Dexron II.
FWIW, the best to use is Redline's MTL. I trashed my current car's T-5 in under 30k miles while I was stationed in Germany. The Dexron couldn't take the heat from the A'bahn. With the replacement T-5 MTL was recommended. That was 135k miles ago. The last 35k has been behind my ZZ4.
Old May 9, 2002 | 02:16 PM
DiecastZ28's Avatar
TTT
Old May 10, 2002 | 04:33 PM
mousemaker's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: 5 speed
1982 - 5W30
1983 - GL5, 80W, or 80W90
1984 - Dexron II
1985 - Dexron II
1986 - Dexron II
1987 - 5W30 Manual Transaxle Fluid (GM part no. 1052931)
1988 - Dexron II
1989 - Dexron II
1990 - Dexron II
1991 - Dexron II
1992 - Dexron II
This is what the Haynes Repair Manual says.
Hope it helps.
Old May 10, 2002 | 08:07 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
my haynes repair manual said this for my 84 5-speed
84- GL5, 80W, or 80W90
but the fluid that i drained was red. should i use the dexron or the gear oil.
Old May 10, 2002 | 08:13 PM
mousemaker's Avatar
Car: 91 RS
Engine: 350 TBI
My manual says that in '84 both the 4 and 5 speeds both took Dexron II, but if yours says different I'd call up the General and ask them.
Old May 10, 2002 | 08:18 PM
DiecastZ28's Avatar
I figured it all out... Thanks guys, I drained the motor oil out, and put in dexron III... I guess that what they make now? Anyways I found a GM service manual for a '85 Firebird and this is what I found...
maroe624
Apr 16, 2017 08:29 AM
LittleFranks
Sep 17, 2015 12:22 PM
midge54
Sep 2, 2015 06:27 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
