Too low gears?
Old May 10, 2002 | 02:53 PM
mousemaker's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: 5 speed
Too low gears?
Right now I've got the stock 5-speed (with 2.95:1 first gear) and a 3.23:1 rear end. My '91 Camaro is daily driven, but I also want to make it a screamer off the line. The 350 that I replace my 305 with has all but eaten my current transmission, so I was thinking about replacing it with a Tremec TKO 5-speed (with the 3.27:1 first gear) and changing my 323 open rear to a 456 posi. With deepening the first gear ration and the rear end giving my a 14.91:1 take off vs. the 9.53:1 it's at now be too low? With the change I'll have a top speed of about 28MPH in first, but will I be able to get any traction when I gun it? I've got 275/60R15 Drag Radials on the rear.
Old May 10, 2002 | 07:54 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
With that steep 1st gear and 456s, you're goin to smoke thru some gears. If this is a daily driver I wouldn't go that low, you're goin to hate highway drivin. Plus you're going to need an engine that pulls past 6k if you want 1/4, though you're 1/8 mile will be nice. I still that you're overkilling it.
Daily driver and an engine that will pull to at least 5k, 3:73s won't be too bad.
Old May 10, 2002 | 07:58 PM
mousemaker's Avatar
Car: 91 RS
Engine: 350 TBI
Old May 11, 2002 | 03:04 AM
mousemaker's Avatar
Car: 91 RS
Engine: 350 TBI
Do you think it would pull the front tires (with the right suspension set up?) Does anybody know what it takes to pull the front tires up, just a little?
Old May 11, 2002 | 10:36 AM
Car: 99 Formula
Axle/Gears: 342
It's going to take more than gears and a steep 1st gear, it's going to take some serious torque and HP.
Old May 11, 2002 | 11:13 AM
82camaro's Avatar
Car: 82 camaro SC
and sticky tires and a spool or locker--you don't want to the front wheels in the air with posi.
Old May 11, 2002 | 12:22 PM
mousemaker's Avatar
Car: 91 RS
Engine: 350 TBI
Gears=Torque
Don't they?
A car with 400ft/lbs, a 3.27 first gear, and a 4.56 rear end will put down (400x3.27x4.56/2) 3000ft/lbs of torque to each rear wheel.
And with 600ft/lbs, a 2.66 first gear, and 3.73s, you will also put down (600x2.66x3.73/2) 3000ft/lbs of torque to those wheels.
Therefore gears equal torque, right?
And why is posi a bad thing when you lift your front tires?
jklein337
Sep 19, 2018 06:23 PM
italiano67
Dec 11, 2016 09:21 AM
lt1z350
Sep 29, 2015 01:50 PM
mizz0313
Aug 12, 2015 06:45 AM
novaderrik
Aug 10, 2015 12:44 PM
