B&m shifter install questions
Old May 13, 2002 | 05:01 AM
BILZ88350's Avatar
I am planning to install a mega shifter into my 88 formula 350 and need advice. i have never attempted this before and would like to know the following; 1) can i use all the existing GM levers at the tranny and cable and just install the shifter itself;2) also what type of adjustments on the cable should i focus in on if i can do theabove. All help would be greatly appreciated.
Old May 13, 2002 | 09:42 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Yes, you can use the stock cable, I did, no adjusting needed or getting under the car. I will require some fabrication of a bracket, you'll have to cut one off and use the stock bracket. Hard to explain, but it will make sense. Never use armorol on the boot. And put some locktite on the handle.
Old May 13, 2002 | 11:09 AM
BILZ88350's Avatar
Thanks for the info Mark
BILZ88350
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
