rearend swap
Old May 14, 2002 | 09:27 AM
1badblue87z's Avatar
rearend swap
I was wondering if it is possible to swap the rearend from my 87 z28 for the rearend out of a 93 z28, and if so what kind of modifications need to be done.
Old May 15, 2002 | 08:51 PM
BOTTLEDZ28's Avatar
Transmission: A4
the rear out of the 93 will bolt right in. the 4th gen reas are about 3" wider then the 3rd gens.but no modifications will be needed to just bolt it in and go. you will have to do something with your brakes and e brake. if you are going from drum to disc then you need an adjustable propotioning valve and the ebrake cables are different.
http://sethirdgen.org/10boltinstall.htm
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
