Banging when pushing in clutch
Old May 15, 2002 | 08:10 PM
Mike89GTA's Avatar
I just started having this problem. When I push in the clutch it makes a loud banging noise. It sounds exactly like somebody is banging a hammer on the bellhousing. I had somebody push on the clutch while I was under the car and it sounds like from down there that it's from the bellhousing too. I don't know what it could be. It doesn't do it every time you push the clutch in but most of the time. It started a couple days ago after I drove it for about 30 miles. I haven't driven it that far since I put the super ram in (or that hard). The t-5 has 125k on it, Centerforce DF has 15k. Thanks guys.
Old May 15, 2002 | 09:03 PM
Mike89GTA's Avatar
Also, the car drives fine, but I'm afraid to drive it very far. Also the slave/master cylinder setup is new.
The wierd thing is if I press the pedal in very slowly, it will bang the same amount. It's like something is binding..
Old May 16, 2002 | 12:20 AM
87irocz350's Avatar
Car: 87 Iroc
Transmission: T-5 3.42's
dont know man, but i just got a new clutch and it cost alot. But when mine went it made a whistling noise.
Just take it in and get the estimate.
Old May 16, 2002 | 10:58 AM
Mike89GTA's Avatar
Yea, I read your post. That sucks. I'm going to probably do it myself since I don't have much money right now. I can take the transmission out in a couple hours I've done it so many times now lol
Old May 16, 2002 | 01:31 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds to me like you have a groove worn in the clutch gear bearing retainer where the throwout bearing slides over it, and it catches on the lip and makes the noise when it breaks loose.
A new bearing retainer is about $30-40, has 4 bolts and a "tubular style" gasket. The pain is, you have to pull the trans to change it.
Old May 16, 2002 | 02:35 PM
Mike89GTA's Avatar
So what's the worst that could happen if I continue to drive it?
Old May 16, 2002 | 03:32 PM
Mike89GTA's Avatar
Oh yea, this is the clutch from your car RB. I heard that you can't use a stock throwout bearing with the centerforce, so I'm glad I ordered the right one. It's working great though other than this problem, which it seems isn't the clutch.
Old May 17, 2002 | 11:47 AM
Mike89GTA's Avatar
btt
Old May 17, 2002 | 03:36 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Oh wow! I wondered how that went. Is the clutch itself OK? It worked great for me, I hope it's treating you right. I almost didn't replace it but since I had already bought one and had the car in pieces I went ahead and changed it out.
It won't really hurt anything if it's what I am suggesting, about all it will do is make the car a bit harder to drive. The bearing retainer is the piece that bolts onto the front of the trans, that the throwout bearing rides on.
RS Reaper
Oct 17, 2018 07:52 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
