How to change rearend fluid
Buy a Chilton or Haynes manual, since you don't already have one. They'll tell you everything you need to know. It's very simple.
Yes, you'll need a gasket. Depending if it's posi or not will tell you which fluid to buy. The guys at Autozone will know. And I don't think the 9 bolt has a drain plug because the 10 bolt doesn't.
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
You'll have to remove the cover to drain the fluid, then scoop out from the bottom. If you can't find a gasket, I have them available at www.9bolt.com
Miles
Diff Solutions
Miles
Diff Solutions
maroe624
Apr 16, 2017 08:29 AM
Thornburg
Aug 25, 2015 01:46 AM
92camaroJoe
Aug 13, 2015 06:07 AM
