drum to disk swap questions
Old May 17, 2002 | 05:03 PM
IROCZ88's Avatar
I have a BW disc brake rear that I want to put in my car. My car currently has drum brakes. I know the master cyl or prop valve was different on the disc brake rear cars, but can I swap it in without changing all that? Has anyone tried this before?
Also, if I can't, can I put the drum brakes from the 10-bolt on the 9-bolt rear?
Old May 18, 2002 | 08:32 AM
IROCZ88's Avatar
What if I just get a new proportioning valve for a disc brake rear?
Old May 19, 2002 | 10:27 PM
IROCZ88's Avatar
ttt
Old May 19, 2002 | 11:18 PM
87 B4Z's Avatar
the master cylinder and pro. valve both have to be replaced
Old May 20, 2002 | 12:41 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Was the RPO code for the BW rear disk's also J65? That's the rear disk code for the regular 10 bolt 7.5 or 7 5/8" axle.
If it IS code J65, and your current master cylinder is the J50 rpo (will be stamped on the bottom side of the body, not the reservoir, of the m/c), then you could keep your J50 disk/drum master cylinder. Apeiron (on the Suspension/Chassis/Brakes) board found an old GM service bulletin that said the J65 m/c was only used to give better "pedal feedback", typically required by a performance driver. But people with new cars complained about the pedal being too hard, so GM said the "fix" was to put a J50 m/c on the car.
But the prop valve is different.
The early master cylinders were cast iron; and can rust... later models are aluminum. You might want to replace yours just for that fact. Beware: Bleeding the m/c is a first class pain in the butt.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
