TH350 trans pan gasket...Recommendations?
Old May 19, 2002 | 04:21 PM
crazeinc's Avatar
Black RVT, Felpro, Generic gasket....what have you had success with?
Old May 19, 2002 | 05:43 PM
ede's Avatar
ede
hammer the dimples around the bolt hole back out, high tack on the trans to hold the gasket in place and ultra copper or ultra gray silicone on the pan, not much. i use the gasket that comes with the filter
Old May 19, 2002 | 07:54 PM
Nordbert's Avatar
I smear Vaseline on both sides of a generic cork gasket and torque the bolts to 100 lbs./in., then retorque to 100 lbs./in.
after installation. The gasket should not bow out at the bolt holes.
Old May 19, 2002 | 08:02 PM
Pro Built Automatics's Avatar
Us ethe Duraprene or Farpack as is. Stay away from the cork & rubber.
maroe624
Apr 16, 2017 08:29 AM
LittleFranks
Sep 17, 2015 12:22 PM
Navy8125
Aug 21, 2015 09:32 AM
mizz0313
Aug 12, 2015 06:45 AM
