Tranny Lockup???
Old May 21, 2002 | 08:59 AM
rsc350's Avatar
Car: 92 Camaro RS
Axle/Gears: 3.73 Truetrac
Tranny Lockup???
I have a 700R4, Is there any easy way to make my tranny lock up like ground a terminal or something, I dont have all the wireing done yet, still have to run VSS too, so I will do it right when I have the money for the speedo and speed buffer and thing, just thought maybe there is a way to trick it to lock up???
Old May 21, 2002 | 01:02 PM
Momar's Avatar
I believe that I have heard someone say something about jumping a couple of the aldl pins but I dont know for sure.
Ben
Old May 21, 2002 | 02:55 PM
transfixleo's Avatar
If the ECM is still functional you can jump the A and F terminals on the ALDL. IF not then you will have to wire up the Tranny so that the A Terminal has 12V and D you cnotrol ground to for L/U.
Old May 21, 2002 | 07:20 PM
rsc350's Avatar
Car: 92 Camaro RS
the ecm is functional but the harness is out of a manual and mine is an automatic so none of the wireing is there, just as for the VSS. I was just wondering if there is a quick fix on the tranny side i can do to get it to lock, till I can get the the bone yard and get the conectors and wires and speed buffer.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
