How do you remove the park brake cable from the shifter?
Installing a B&M Megashifter and can't figure out how to get it off. The shifter cable came off easily after pulling out the cotter pin, but this seems to be a bit more tricky.
Engine: 4++,350 & 305 CIs
Re: How do you remove the park brake cable from the shifter?
The thread is 10yrs old and he hasnt been on since 05... We will never know but the answer is out there....................
N A factory service manual
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
The cable if like my 91 (i dont see why therewould be a difference) is on the lever like a throttle cable on a TB, it fits in a channel with a cylinder stop on the end that twists and slides into the hole....the zip ties keep the slack in the channel, if there are no white/clear zip ties on it (factory) them someone has already messed with it at some point. be sure to replace them when done
This is under car, mind you the cable you see is a 4th GEN, im showing this for reference only!!
under car...
under car...
This is what was asked about, correct?
1992rs/ss
Jan 31, 2025 05:10 PM
Eric-86sc
Apr 3, 2016 03:52 PM
NBrehm
Aug 25, 2015 11:49 PM
