Auto to T56 Swappers: Did you change your chip?
Old May 24, 2002 | 01:21 PM
m23haz's Avatar
Car: 91 Camaro Z28
Engine: 5.7 TPI
I am about to do the swap and I have heard conflicting stories on how it will run with the stock auto chip in it. What did you guys do and how does it run?
Old May 24, 2002 | 06:00 PM
kevinc's Avatar
Car: 1982 Z28
At first I ran my auto-trans chip and it worked fairly well, only bad thing was the idle speed while moving and in neutral or w/ the clutch in. The AUJP code wanted to hold the idle speed at ~1200rpm while the car was moving...I could see it on my scanner, desired idle RPM was ~1200rpm. As soon as I came to a stop, it would drop down to 750rpm.
I changed to code for a '91 Vette with ZF6 trans and the behavior stopped, it now snaps right down to 750rpm when I drop out of gear and coast.
Good luck w/ your swap!
-Kevin
Old May 24, 2002 | 07:58 PM
m23haz's Avatar
Car: 91 Camaro Z28
Engine: 5.7 TPI
Thanks for the info Kevin. Anyone else experience the same?
Old May 25, 2002 | 12:38 AM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
I changed my chip. I have the equipment to customize and burn chips so it was no big deal.
But if I didn't have the equipment or money I would at least get a memcal (chip) from the dealer of a car that did have a manual trans and had the same engine, unless you have a 350, in which case you aren't going to find one.
Old May 25, 2002 | 09:18 AM
m23haz's Avatar
Car: 91 Camaro Z28
Engine: 5.7 TPI
Kevin, how did you "change to code for a 91 vette"? Did you do the chip yourself or did you actually put in a chip from a 91 vette?
Would anyone be nice enough to help me do a chip ?????
Old May 25, 2002 | 01:43 PM
kevinc's Avatar
Car: 1982 Z28
I burned a chip myself using the Vette binary as a starting point, copying in my previous VE and spark table data.
Check the diy-prom forum and TRAXXION's article at the top of the message list to get started on your own.
Old May 28, 2002 | 06:10 PM
IROCracer's Avatar
I have a 350 and left my auto chip in...didn't notice any difference other than the car being an assload more fun to drive...heh heh heh.
Kelly
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
jharrison5
Aug 19, 2015 05:53 PM
Exxon Limited
Aug 9, 2015 08:13 PM
