1983 Trans Am Flywheel specs
Can anyone tell me:
Re: 1983 Trans Am with GM corporate 305CI engine.
#1 what is the Diameter of a Stock Flywheel. ( inches )
#2 How many teeth does it has:
Year: 1983
( 305 CI V8 with stock 5-speed manual transmission)
I am trying to find out which part number to order for a Power Master Chevy Gear reduction High Torque starter, for this application.
Jackpiner......
Year: 1983
Jackpiner......
If you are running the stock T-5 Transmission that means you will need the 153 tooth flywheel. I'm not sure of the diameter. If im not mistaken there are just two flywheels, the larger 168 and the 153.
BlackphantomZ28
Aug 31, 2015 10:29 AM
