400 hp T-5?
Old May 25, 2002 | 03:18 AM
titeride85's Avatar
400 hp T-5?
I know nobody likes them and the stock T-5's suck, but does anybody know if there are parts available to make this tranny handle upwards of 400 hp? I would like to keep the 5 speed just for originallity rather than the T-56 swap. I figure if it can be done it should not cost any more than the T-56 swap.
Can it be done and who can I contact about the parts or even a builder to do it?
Old May 25, 2002 | 07:22 AM
Intercepter's Avatar
I had my NWC T5 behind a 383 pushing 450hp for 3 years with no problems. I pulled it apart at the end of each year and it looked fine. I replaced the syncros on the second year just for a freshen up. As long as you don't beat it you should not have too many problems. Synthetic ATF is a must!
Old May 25, 2002 | 01:17 PM
Little GTA's Avatar
T-5
Liberty Transmission
Old May 25, 2002 | 04:05 PM
Tom Keliher's Avatar
I had this Counter Gear Stabilizer installed in my T-5 when it was rebuilt. I'm running an estimated 400 HP (according to Desktop Dyno) and so far the tranny is just fine after a year of use.
http://www.5speeds.com/t5.htm
Old May 25, 2002 | 10:10 PM
camaro6spd's Avatar
yeah 400 hp with 250 ft/lbs of torque....lol...naaa just kiddn i own a NWC T5
Old May 26, 2002 | 07:30 PM
83 MidniteZ's Avatar
My NWC T-5 is still holding up behind my beast....granted it is grinding, but the grinding started before the 305 swap when the guy at the tranny shop screwed it up!!!
Old May 27, 2002 | 11:22 AM
urbman's Avatar
Keeping in mind the obvious...
Torque doesn't kill trannys, strain kills trannys.
If your setup will not allow the car to "hook up"
that is if you can't get near a 1.7 60ft time
you'll be fine. The tranny will become a weak point
when the clutch will hold and you have the traction
for a "good" launch (posi, sticky tires, good geometry)
If your in the 2.0 second range only stupid abuse
will damage the tranny.
PurelyPMD
May 5, 2016 04:57 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
luvofjah
Sep 26, 2015 08:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
