Rearend Help Needed
Old May 27, 2002 | 04:30 PM
duke_mushroom's Avatar
Rearend Help Needed
Would it be easier to just find a rearend with the gears I want in it or to buy some gears, a posi, and have a proffessinal install them. A friend of mine has a guy who will put the gears and posi in for $600, only problem is that this guy lives in Lubbock. Anyone have any other ideas? My rear is in good shape but I should probably check it out just in case.
Old May 27, 2002 | 07:50 PM
ede's Avatar
ede
gears and install kit will run you 350, plus 100 for a posi. i tihnk people tend to over chage for gear installs, i'd do it for 100 with the rear out of the car, so 600 isn't bad for new parts. if you could find the gears you want a rear should run you around 200-300 at a swap meet
Old May 29, 2002 | 09:29 AM
I talked to my friend's mechanic yesterday and he said he knows a guy with an '01 Camaro rear. It's got disc brakes and he said a 3.42 gear ratio but he wasn't sure. He said he'd get back to me with all the info and a price. How does this sound? Will it just replace the old rear or will it need to be modified?
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
