tranny cooler line size?
I'm having a bitch of a time getting the two tranny cooler line fittings off, on the tranny end. Are they 1/2" or 3/8"? Or are they metric? I am using a 1/2" standard wrench and it is just not happening. I can't get a good angle to put torque on to the wrench, the underside of the car gets in the way. The tranny is lowered a little bit too. What am I doing wrong?
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
i'm running ath350 so the nut is probably different but i used a crows foot on a ratchet and extension. i unbolted the crossmember and lowered it a little with a floorjack that helped allot
toronto formula
Nov 10, 2015 06:17 AM
knight72
Aug 10, 2015 09:32 PM
