Cracked tranny case? Help me Probuilt and transfixleo
Car: '89 RS
Engine: 9C1 w/ TPI
Transmission: rebuilt 700R4
I took my tranny in to be rebuilt today...and when I stopped by at the end of the day and they had it torn apart...the guy showed me that a small chunck was missing out of the bell housing....right next to a bolt hole. (about the size of your thumb. He says that this would cause some vibration...and I've had a hella vibration as long as i can remember (worst at 90 MPH). Well he said the rebuild would be $1,100 w/ a 1 year warranty (sounds about right doesn't it?)...but here's the thing...he says he has to get a remand case...and it'll be an extra $300....taking my total to $1,400
Does that sound right for a tranny case? Can the current one be fixed?
Does that sound right for a tranny case? Can the current one be fixed? At $1400 aren't you about $100-$200 short of just getting a complete trans, no exchange, from Pro-Built? It migh be another option to consider, unless you have a love affair with your exisiting trans. (LOL) I'm not sure what a reman case goes for. The exisiting case could be tig welded, but you would have to consider that cost, the additional running around to find a guy to weld it, & whether the weld is in a non-critical zone. It would be cheaper just to get a good used case. The problem is now, you are partially commited to the shop that disassembled your trans. Hope it all works out for you.
Car: '89 RS
Engine: 9C1 w/ TPI
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Core charge seems to run around 200....I think he is a little high.
As for the hole...Ive been running with one ear gone for about 8mo now.(installing new tranny this weekend). I cant even tell its missing.
Dont think I would pay for a rebuild in a broken case though.
Car: 1986 Firebird
Engine: 2.8 V6
I remember that "catch"... when Lee Myles did my trans, they tore it apart, told me it was completely shot, showed me broken pieces, and told me a price. I said I'd think about it- then the guy tells me it'd be $300 labor if I don't have the work done. Hm; you'd think that'd be mentioned up front, right?
Why not get a junkyard 700r4, tear the guts out, and give it to 'em? "Hey, here's a case. It was in my friend's basement."
I've been quoted $100 for a 700r4 from the junkyard I usually go to.
I've been quoted $100 for a 700r4 from the junkyard I usually go to. Thread Starter
Car: '89 RS
Engine: 9C1 w/ TPI
I've been quoted $100 for a 700r4 from the junkyard I usually go to. Unless the hole is at the alignment dowel, and that should be checked for wear too by the way, I don't buy that it caused your vibration. More likely your Tires/Wheels/Driveshaft. There is nothing special about the case either. I don't mind charging for a part that is needed but it sounds like he is trying to hit a home run. Best part is, if he does change it he will probably stick it into the next job that comes along.
Car: '89 RS
Engine: 9C1 w/ TPI
Car: '89 RS
Engine: 9C1 w/ TPI
"he's just the manager...so that gives me less reason to believe that he would try to rip me off"
Ever hear of commission?
