Can I get Rid of TV cable????
Old May 28, 2002 | 08:35 PM
Ratchet's Avatar
I have a 700r4 out of a 92 camaro that I am going to put behind a non computer controlled (carbed) 355. I will be using a Ratchet shifter and intend to shift myself when I want to pass someone or I am at the drags.
Can I just block of the hole for the TV cable and leave it out???
What does the TV cable actually do??
Old May 28, 2002 | 08:43 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Unlike the TH350 and 400 that uses vaccum to shift the tranny the 700R4 uses line pressure to shift. The TV cable controls the line pressure by opening a valve. In short,you need the TV cable for the tranny to shift.
Old May 28, 2002 | 09:30 PM
82camaro's Avatar
Car: 82 camaro SC
Look at it this way, without the cable how can the tranny 'know' when you mash the throttle and want to go fast--shifting at the redline. Or light throttle around town shifting at low rpms. It needs to know the throttle position to work.
Old May 29, 2002 | 08:27 AM
Ratchet's Avatar
I understand that if all you want to do is press on the gas pedal and let the transmission shift for you that you must use the TV cable
But would there be any problem with starting with the car in first gear and manually shifting into second, third and forth.
Sort of like driving a standard without having to use the clutch pedal.
Old May 29, 2002 | 08:57 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
If you were to leave it out the trans would "think" the engine was at idle & would not increase the line pressure which is needed for shifts at higher rpms. Low line presure @ high rpm = toasted trans. So the answer is you need it.
Old May 30, 2002 | 02:01 PM
Ratchet's Avatar
Thanks RickTpi!
I get it now I will install the TV cable with the trany.
I have another question though. This transmission has a lock up torque converter and an electrical plug 4 openings with 3 pins in it. do I need to do anything with this as this is a totally non computer car.
Old May 30, 2002 | 02:32 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
If you want the converter to still lock up you will need to get a lock up switch from painless wiring (part# PRF-60109) that uses vaccum to activate the lockup solenoid.
Old May 30, 2002 | 02:36 PM
Ricktpi's Avatar
You will need a kit to lock up the converter. Painless & B&M make them as well as others. If you let it go you can overheat the trans & shorten its life.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
Zell1luk
Sep 29, 2015 10:36 AM
