th350 kickdown ques.....
Just a quick question. Do I need to have the Kickdown cable or can I ditch it and block off the hole? The bolt that holds the cable sleeving is broke off and the sleeve is loose, which cause it to leak tranny fluid very badly. I would like to take care of this as soon as possible as this is becoming a very annoying problem.
Are you referring to the TV Cable on a 700? If so then you MUST have it and it MUST be set correctly. I say this because your signature lists a 700.
If you are talking about a TH350, I know some people run W/O it. I prefer to have it but it isn't as critical as a 700.
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
You will have to shift manualy..as leo said, not the best thing to do.
Ive been wondering...is that paint real life or phot shop?
