car wont shift out of drive
Old Jun 3, 2002 | 03:25 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
last night i turned off my car while it was in OD. i then proceeded to shift from OD to P to keep the car in place. the shifter lever slid into P way to easily. i then found i could slide the gear shifter without pressing the button. i tried to start the car after that, to find that it did start, then lurched forward... it was still in the OD position. anyone have a similar problem that your shift lever wont go into gear? luckily its stuck in OD so i can move the car, and weirdly, it still starts even though its not in N or P. by the way, my car is a 1984 Camaro Z28 with the LG4 engine and a 700R4 auto trans. thanks in advance
Old Jun 3, 2002 | 05:23 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Sounds like you broke your shifter cable.Luckily you were home when it happened,mine broke in park at a gas station and I had to trust a guy to sit in the car and hold the brakes while I layed under it and moved the lever on the tranny
Old Jun 3, 2002 | 06:44 PM
82camaro's Avatar
Car: 82 camaro SC
Broken or unhooked cable. Mine did it in 1st gear. The neutral safety switch is in the shifter, not the tranny. So, if the shifter is in N or P it will try to start--regardless of what gear the tranny is actually in.
Old Jun 3, 2002 | 08:12 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
how hard is it to replace a shifter cable, and how long would it take? i would have access to a lift (i work in a garage)
maroe624
Apr 16, 2017 08:29 AM
Wade787b
Sep 29, 2015 01:15 PM
jharrison5
Aug 19, 2015 05:53 PM
dhonda200
Aug 11, 2015 11:50 PM
gwade12
Aug 8, 2015 08:17 AM
