T56... what starter do I need?
Old Jun 6, 2002 | 10:53 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
I tried doing a search, but I found alot of conflicting info. I'm finishing up the install, and I went to try to put my original starter back on today, and it wouldn't fit. I'm not too sure where it hits, cause it was getting dark already, but I am going to take a better look at it tomorrow. Anyways, what starter are you guys with T56s using?
Old Jun 6, 2002 | 11:12 PM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
get a starter from a manual V8 camaro, say an 89 305 TPI (vin F) with a 5-speed. Tha's what I used.
Old Jun 7, 2002 | 07:01 AM
jimbuck0's Avatar
Or get a mini starter, I used one from a 96 LT1. It is hitting on the bellhousing. You can grind the hole bigger and it will work. The only problem I had with the mini starter, the wires were just barely long enough, had to trace them and pull a couple of tie backs.
Jim Buckingham
Old Jun 7, 2002 | 09:07 AM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
I think I'm gonna try a starter from a manual car. Thirdgens used the same starter from 88-92, right? I guess if it works, then that would mean that the auto and manual starters are different, which would prove 50% of the people I've talked to wrong, and prove the other half correct.
Thanks for your help guys.
Old Jun 9, 2002 | 08:59 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
I haven't had a chance to do anything on the car until today. I went out to try to see why the starter wouldn't fit today, and I must have been eating major **** last time, cause it did fit.
Old Jun 10, 2002 | 02:42 PM
IROCracer's Avatar
I did the same as jimbuck....yeah those wires are some short bastards eh?
The cool part is trying to take back the stock starter as a core. Make sure you take it back later, you can fit it in the box if you work it right. My *** was running short on money and nearing the end of the project, so I tried taking the core in while getting the new one, you shoulda seen the look on the dumbass' face. I talked him into taking it. Told him that they started meaking them smalled now because of heat soaking problems from the exhaust.
I swear they'll let anyone work at O'Reilley's.
Kelly
Old Jun 13, 2002 | 01:26 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
From everything I've read, the LO3 starter from an automatic will work just fine. I'm counting on it......
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
