T-5 to T-10 swap
Old Jun 7, 2002 | 04:49 PM
wingnut's Avatar
Car: '91 Firebird
Engine: 408 SBC
T-5 to T-10 swap
I'm scrapping the 305 TBI in my '91 Firebird and putting a carburated 400 in it's place. The 400 puts out roughly 430 HP. Obviously, it would be wise of me to replace my stock T-5 tranny during the swap. I'm considering the Richmond Super T-10 to fill the void. I don't know much about this swap. I was hoping that the bell housing from my T-5 would bolt up to the T-10. Anyone know if this is the case? Also, will I be able to use my stock drive shaft?
Old Jun 8, 2002 | 08:24 AM
ede's Avatar
ede
i'd be worrying more about the clutch, mechanical and hydrolic. you'd be smart to buy a blow bell for a sbc and the t-10 to bolt to
Old Jun 8, 2002 | 02:36 PM
cvpde37's Avatar
I've never done the swap myself, but have considered it and researched it a little bit. I can tell you that the T5 bellhousing will not work because it is set up for a canted mounting. The T10 mounts straight up. I have a lakewood bellhousing that is drilled and tapper for both the canted and straight up. It also has the mounting for the hydraulic slave cylinder. I haven't researched what type of clutch set up you could run and keep the hydraulics.
midge54
Sep 2, 2015 06:27 PM
Cacike
Aug 27, 2015 05:10 PM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
