700R4 to T56, which brake pedal to use?
Car: 91 camaro
Engine: 383
I figure I need a brake pedal from a manual tranny fbody, but should I use one from a thirdgen or a fourthgen? Or does it not even matter which one I get?
Transmission: A4
I belive the clutch and brake pedal is on one bracket. Take a look at a manual car and see how they are bolted up. if all 3 pedals are seperate then just find some pedals from any car. I dont think there is much of a difference.
I just put my 4th gen pedals in today. The clutch and brake pedal are on the same bracket, and you just cut off the bracket for the gas pedal. It wasn't terribly hard, but does try your patience at times.
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
