Not a 3rd Gen question, but a first gen.
Old Jun 13, 2002 | 11:20 PM
nodnarb's Avatar
Ok guys, I know you all are really smart about stuff like this, so here's my question.
I have a 69 Camaro RS and it currently has a Turbo 350 in it with 3:55 gears. Just going down the road it feels like it needs to shift again after it gets into 3rd gear. So, I was thinking maybe a transmission swap. A 700 R4 would be nice, but would that require cutting of the floorboard to make it fit? I think it's quite a bit larger than a Turbo 350. Also, what about a 200 4R? I read those were the same size as a Turbo 350. What kind of cars came with a 200 4R? I think some 3rd generation Camaros and Firebirds came with 700 R4's, right?
Old Jun 13, 2002 | 11:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The vast majority of 3rd gens came with 700's.
But, properly built, the TH200R4 is the superior transmission. It'll cost you, but give Dana at Pro Built a call. He'll set you up with one that'll do the trick for you. I've got similar dreams for the '57, just waiting for my wish to be granted...
Old Jun 14, 2002 | 10:03 AM
nodnarb's Avatar
What about cutting the floorboards for a 69 Camaro? Shouldnt the 200 4R slip right in, if it's the same size as a Turbo 350 and I have a Turbo 350 in it, it should just bolt up, right? And what do you mean if they're built right? What about a stock Transmission pulled out of a car, maybe with a shift kit in it?
Old Jun 14, 2002 | 01:08 PM
ede's Avatar
ede
i tihnk a 700r4 is the same size as a th400 and th400s came in 1st gens
Old Jun 14, 2002 | 02:28 PM
five7kid's Avatar
Check this site: http://www.tciauto.com/tech_info/trans_dims.htm
The overall length of the TH350 and TH200 are the same, but the distance from bellhousing to rear mount is 6-5/8" longer on the TH200.
It should fit in the tunnel with no modifications.
I don't know a lot about the TH200 as-delivered from the factory. But, I understand they need a little more help than just a kit. Dana will set you straight on all that.
Terrell351
Jun 13, 2021 01:13 PM
69 Six Pack
Oct 5, 2015 07:51 PM
redmaroz
Aug 16, 2015 11:40 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
reiderz iroc
Aug 13, 2015 04:57 PM
