car makes clunking sound when making mild right turns...
Whenever I turn right down a street, my car makes a "clunk" noise. I have no idea what this is. What could it be? Also, I have just noticed that when accelerating a little bit in first, it seems to run a bit rough and the dash board shakes a bit, then when it goes into second, it feels like it runs even rougher, unless I accelerate more. It doesn't sound like the motor is the problem, becuase I can't hear any problems when in park and just revving it. Any ideas?
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Can you give us more information? Like where is the clunk comming from? Front or rear?
Thanks for the response! I am not really too mechanically inclined, so I have no idea about what this could be. I was just concerned because I remember a long time ago some guy driving my car saying it's good there was no "clunking" sound when turning because most IROC's have that and it means something went bad but I can't remember what it was. I think it sounds like it's coming from the back.
It's in the wheel well on that side of the car, and you'd be surprised how many times people bring their cars to the shop with this "problem". Anyways, if its not that start checking the rubber bushings on the shocks, and rest of the rear suspension.... then check for loose bolts or anything else unusual in that area.Hellraiser
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
and i suppose busted sway bar end links in rear can make a snap or pop over deep dips like at end of driveway onto main road, right ? sometimes on a good hard turn, but not that often.
mustangman65_79
Aug 11, 2015 03:17 PM
