At What Temp Do You Need A Tranny Cooler?
85 3rd gen. 170* t-stadt. Cooling fan on toggle switch. I usually keep coolant in 160*-200* range, even in heavy traffic with A/C on. This is much cooler than factory set-up of cooling fan not engaging until 220* or more, with a 195*t-stadt. Therefore, my Tranny temp would also be in this range.........do I really need a Transmission cooler? Thanks.
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I'd get one just 'cause.
I have a 70268 B&M trans cooler. My trans fluid usually runs about 150*F when it's hot outside and around 125*F at night. I can tell you from experience that the shift quality gets worse and worse when it gets to 180*F and above. But that doesn't happen anymore since I relocated the cooler to the grill area and put the B&M in series after the stock radiator cooler.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It varies. The engine coolent is "usually" 180 degrees. If the tranny oil is hotter and goes through the rad cooler first, it will lose some of it's heat into the coolent. If you cooling system isn't efficient enough this can cause engine overheating.
Running a stand alone tranny cooler isolates the heat from the tranny oil to the engine coolent. Run the biggest cooler you can in whatever limited space you choose to put it. It doesn't "have" to be in front of the rad. You could mount it horizontal with a fan over it. Just as long as there's air flow across the cooler, it will work.
Tranny oil operates around the same temperature as the engine. You should never let it get above 250 degrees.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
