T56 question
Old Jun 23, 2002 | 10:46 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
T56 question
I have everything I need for the swap, minus a few things. One: my torque arm and crossmember, which are back ordered, and two: The clutch fork.
As far as the clutch fork goes, I thought I read something about a piece that goes along with it. Or does it just connect to the throwout bearing? I have the clutch disk, pressure plate, throwout bearing, flywheel, and hydrolic assembly.
I am pretty unknowledgeable when it comes to trannies, so please for give me. Thank you in advance
Old Jun 24, 2002 | 04:05 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
please correct me if i'm wrong, but dont T56's have a concentric slave cylinder......................there is no clutch fork......................
Old Jun 24, 2002 | 12:19 PM
Engine: LO3;383tpi
If it does, then I guess I'm in luck. What does it look like and how could I tell. I took a look in the 93-up haynes manual, and it showed a clutch fork, but I may have accidentally been looking at the v6 5 speed. Can anyone tell me for sure. Thank you, Roy
Old Jun 24, 2002 | 12:29 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
Are you talking about an aftermarket T56? If yours isn't aftermarket, you don't need a new torque arm, just a crossmember. All 82-02 camaros use the same size torque arm, so unless you went aftermarket, your old torque arm is fine.
As far as the clutch fork, yes it has one. The slave cylinder pushes against the clutch fork, which is what pulls the throwout bearing.
Old Jun 25, 2002 | 06:52 PM
kevinc's Avatar
Car: 1982 Z28
Wow, that's news to me...seeing how my '82 came with a TH200C trans which is ~4 inches shorter than a TH700. Holding the torque arm from the original setup next to a later-model 3rd gen that came w/ a TH700, there's about 3-4" difference in length.
Might want to check your facts before posting an error and throwing some poor guy off track.
Old Jun 25, 2002 | 07:22 PM
ummmmmm i am 99.99% sure he has a 1990 RS
Old Jun 25, 2002 | 09:01 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
You can reuse your original driveshaft and torque arm IF the tranny is an OEM t-56 (From a 700R4 or T-5).
The aftermarket t-56 uses different length torque arm and driveshaft.
Afternmarket t-56 uses a conventional clutch while the OEM needs the funky backazzwards setup.
An LS1 OEM t-56 has no clutch fork, an LT1 does.
Old Jun 26, 2002 | 06:27 PM
JAY87GTA's Avatar
You will need the torque arm mount off the T56 tranny as well. The mounts are not the same, and you can't put your's on the t56.
Old Jun 26, 2002 | 06:31 PM
ok thanx for clearing that up
we dont get many LT1's at our shop
my friend overhauled a LS1 T56 about 3 weeks ago.................
lets put it this way......he was NOT happy with his flat-rate paycheck that week
19irocz85
Aug 26, 2015 07:54 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
