I have a question about the 9 bolt rear end in my IROC
Old Jun 23, 2002 | 11:44 PM
89Irocz23's Avatar
Well there is nothing wrong with it at all or anything like that. It just seems gears and so on are soo much more than a 10 bolt. Everything is hard to find for it. Im debating on finding a 4th gen rear or maybe a 10 bolt. Would I be better off with this 9 bolt or should I find a 10 bolt. There is nothing wrong with the 9 bolt gears look fine everything is fine. Its a 3.27 gear ratio also.
Old Jun 24, 2002 | 09:57 AM
KeithO's Avatar
The 9-bolt is much stronger, but like you say, parts are hard to find. Parts are available here: www.diffsolutions.com
If it ain't broke, why replace it? It's much stronger than the 10-bolt. I'd delay a decision until you need to do something.
BTW - I'd love to have a 3.27 9-bolt for my car. Just love to.
Old Jun 24, 2002 | 11:45 AM
MdFormula350's Avatar
I just found out that that www.9bolt.com = www.diffsolutions.com
If the 10 bolt is way weaker than why do the later thirdgen's have them?? I like my 10bolt disk brake 3.23 posi
Old Jun 24, 2002 | 06:38 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
i also have a 3.27 9-bolt posi in my car and i wunt to get gears but they are soi expensive and if my posi wears out or i break an axle then i am screwed cause i don't have the money for a new carrier and u can't find axles. i also have a 3.23 10-bolt from my car thats just chillin with nuthin wrogn withit except its not a posi, should i just get a locker unit and gears for it cause with the locker unit by powertraxs won't it be stronger then a 9-bolt??
Old Jun 25, 2002 | 08:23 AM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Yep. It started out as 9bolt because I was offering only 9 bolt parts, but I am currently working on expanding into other types of rears too (some for 3rd gens, some not). Hence the change to Diff Solutions
[bold]COST!!!![/bold].
Nope.
Miles
Diff Solutions
Old Jun 25, 2002 | 12:30 PM
Momar's Avatar
As far as cost of changing gears you have 3.27s so you already have a series 3 carrier. The gears are expensive, but I think it is worth the strength especially if you already have the series 3 carrier. I have also heard that moser makes 9 bolt axles.
Ben
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
BlackBoulder
Aug 11, 2015 11:15 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
