important question
Old Jun 25, 2002 | 04:10 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
important question
if the front seal where the t.c. goes into tranny is bad and the car spits fluid when its running, is it hurting the tranny to run the car in park or nuetral(with very little to no fluid)?
Reason im asking is my front seal went out and we have to pull it to shop to fix it, and if i leave the car running while its being pulled, ill still have power steering and brakes, otherwise i wont, ofcourse the tranny is a good old reliable 700r-4( )
Old Jun 25, 2002 | 06:49 PM
kevinc's Avatar
Car: 1982 Z28
Bad idea operating the engine w/ no trans fluid, either idling stationary or being towed w/ the rear wheels on the ground.
If you just can't get a flatbed rollback truck to tow it, you can remove the driveshaft for wheels-on-ground towing so the trans isn't damaged.
92GTA
Apr 9, 2016 07:39 AM
E_S
Aug 29, 2015 04:09 AM
redmaroz
Aug 16, 2015 11:40 PM
Ozz1967
Aug 16, 2015 10:23 PM
gta power
Aug 13, 2015 06:15 AM
