Changed rear gear and went slower???
Old Jun 26, 2002 | 02:30 PM
FirstShot002's Avatar
I changed the rear gear in my 88 SC Camaro Convertible. BONE STOCK 305 TBI. Original gear was 2.73 changed to a 3.42 Posi. Originally i had the problem of wheel spin with the open rear gear. I have 16 x 8 IROC rims with 255 x 55 16 Goodyear Eagle. Now with the 3.42 gears I still have the same problem with wheel spin if launch at anything above idle. ALSO it runs out or RPM and WILL NOT shift into 3rd for what seems forever.
first times 10.09 in 1/8
after gear change 10.84 in 1/8
Any suggestions????
Old Jun 26, 2002 | 02:40 PM
nsimmons's Avatar
the gears are too steep, all they do is take the engine out of its power band earlier, either movie the power band up or recalibrate your tranny to shift sooner.
Old Jun 26, 2002 | 03:48 PM
opps forgot...this car has a 700R4 tranny
Old Jun 26, 2002 | 04:55 PM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
not shifting into third is common with 700R4s. I had that problem but I fixed it by installing a T-56. I'm pretty sure a Transgo has a fix for that problem.
Old Jun 26, 2002 | 06:05 PM
burnoutrpm's Avatar
agreed 700r-4's suck ***!!! they have so many design flaws its not even funny very soon im converting to a standard. ive had my fill of 700's many issues. by the way your right thats just many problems witht the oh so wonderfull 700!!
Old Jun 27, 2002 | 02:34 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Hey burnoutrpm, Let me RESTATE that for you, "STOCK 700R4's suck"
I think Pro-built would take offense to your comment, at the very least. I am sure that your 700R4 junk transmissions weren't from Pro-Built, right? Don't throw out a stupid statement like that without qualifying it with specific experience...Otherwise you sound like the ******* who spouts, "Camaros suck". That kind of intellectual argument is pointless.
As for the gear issues, it is because your powerband in a TBI car is from 1000-4000 rpm...numerically higher gears only work well if your powerband is higher to match. I would suggest upgrading the engine to take advantage of the posi and better gears.
Old Jun 27, 2002 | 05:28 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
What? Not shifting into 3rd? Never heard of that.
Anyways, what's your 60 ft times comparitive. That will be the biggest indicator, you said you're still spinning but maybe more so now. And not shifting into 3rd isn't helping your times if it shifted into 3rd before. You should have knocked a few 1/10ths off.
Me, I made the mistake like someone earlier said, I went from 2:73s to 3:73s also added a cat-back and knocked off only 1/10th.
Old Jun 27, 2002 | 05:47 PM
Engine: 3.6L
I noticed that problem after I went to the track. I did a search on the subject and found a dozen or so posts about it. It's a problem you don't really notice on the street, at least for me, because it's over by aroung 60 mph (if that). Normally you aren't going ***** out til 85 mph.
Old Jun 27, 2002 | 06:37 PM
TBI305Camaro's Avatar
sometimes my car wont shift into third at WOT....im seriously thinking about getting the bills together for a t56 swap.
Old Jun 27, 2002 | 09:34 PM
OK..it DID NOT shift into 3rd BEFORE the gear change but i wasnt out of RPMS either. IF I try and power brake at the line I cant get any rpms up before the tires spin. About 2/3s the track it is maxed and needs 3rd which unfortunatly it doesnt get Looks like the engine is the next step.
Old Jun 27, 2002 | 10:03 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Well, like one guy said I have never heard of a 700R4 not shifting into third but I have heard of them not shifting into forth???? Heck I would fix the tranny next.
Auggie
Old Jun 27, 2002 | 10:31 PM
nsimmons's Avatar
yeah if your cars taking forever to shift into 3rd, then its spending alot of time outside its power band. Get it fixed so it shifts at a resonable rpm and you should drop some et
Old Jun 27, 2002 | 10:56 PM
Any suggestions as to the Tranny fix. It shifts fine under normal driving
Old Jun 28, 2002 | 12:59 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
now you have gears its time for valvetrain to match. (or a new engine with correct valvetrain) flow flow flow is the key, cam intake heads. cam intake heads. rinse lather repeat. oh, and get a working tranny first.
Old Jun 30, 2002 | 04:42 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
have you tried adjusting your TV cable?
Old Jun 30, 2002 | 12:08 PM
82camaro's Avatar
Car: 82 camaro SC
"IF I try and power brake at the line I cant get any rpms up before the tires spin" It's going to be much easier to do a burnout with the deeper gears. If you need to launch at a higher rpm, try a higher stall converter. You may need some traction mods to hook-up better. You added traction with posi, and hurt off the line traction with deeper gears. You just gotta learn how to lauch without spin. Getting the tranny fixed will help your times alot.
hectre13
Dec 11, 2023 08:14 AM
customblackbird
Aug 15, 2021 10:16 PM
jklein337
Sep 19, 2018 06:23 PM
hectre13
Aug 26, 2015 08:17 AM
Jlanz55
Aug 17, 2015 07:15 AM
