non lockup converter in a lockup tranny
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
would it be ok to put a non lock up converter in my transmission that came stock with a lockup converter? i put a carb on my car and have since lost my stock lockup function is that ok?
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
You can run a non lockup conveter and be ok. Or you could by the Painless wiring vaccum lockup kit (part # PRF-60109) that lets the converter lockup with out a computer on carbed vehicles.
Originally posted by JoelOl75
You need to plug passages in the pump to run a non-lockup converter.
Trans-Go has a non-lockup valve that requires you to drop the pan & the TCC solenoid & replace the existing TCC valve with the Trans-Go, that's it. Let me know if I can be of help?
