Metric or SAE ??
Old Jul 2, 2002 | 04:19 PM
gclay's Avatar
Metric or SAE ??
I am Swapping a manual 5 speed from a 1983 z-28 into a 1984 z-28 with a 700r4. I have removed the 5 speed. I have completed the prerequisite tasks for removing the 700R4 and expect to remove it during the 4rth of july holiday.
My Question:
I experianced some frustration in removing the manual transmission trying to use a 15mm socket. When I switched to 9/16 ths it worked much better.
I have heard that there are 2 bolts on the automatic that a real PITA to remove, so I would like to know before I start if anybody knows what size bolts hold the 700r4 to the engine.
Thank you in advance
George Clay
Old Jul 2, 2002 | 04:29 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
3/8"-16 bolts, so you need a 9/16" wrench
Old Jul 2, 2002 | 04:32 PM
JoelOl75's Avatar
Actually use a 9/16" socket on a swivel with a bunch of extensions. I usually grab 1/2" drive for this as the 3/8" flexes too much. Drop the x-member down and start at the top, all the bolts are very accessible from under the car, just make sure you don't smash the distributer cap off the firewall...
Old Jul 2, 2002 | 04:36 PM
gclay's Avatar
Thanks, For the valuable info.... I have already removed the distributor cap in case of problems banging against the firewall
AUZ28
Aug 26, 2015 06:08 PM
AUZ28
Interior Parts Wanted
Aug 25, 2015 07:29 AM
Project86
Aug 31, 2001 11:35 AM
Kyle F
Car Audio
May 3, 2001 12:58 PM
