can i do this to my 2.73 open differintal???
From: Tucson AZ where the 3k ft of elevation kills your time
Car: 89 camaro rs
Engine: 383 .06 over
Transmission: th350
Axle/Gears: 3.73 10 bolt
I have 2.73 gears with an open differintal and i want to change my gears to 3.23 postive traction. can i change my differintal or do i have to buy a new rearend?
Now thats about the dumbest question I 've ever seen. No YOU can't change them if you have to ask, but you can hire someone else to. The parts are available, and no you don't need to change the whole rear end. Sorry for the truth.....:lala:
Car: 89 camaro rs
Transmission: th350
rustynut,
Now if I know that would i have to post a thread to find out?
NOOOO.....
So next time try not to be so f****smart to those that are ignorant to that wich they question.
Did you go to some car school to learn what you know or did you learn it all by asking everybody questions? BECAUSE I DIDN'T GO TO NO F*** SCHOOL SO BACK OFF.
By the way thanks for the reply.
NOOOO.....
Transmission: 4L80E/4L80E
Okay, cool your jets, guys.
I'll apologize for Rusty (I've been known to get a little too sarcastic myself).
The best way to do this would be to buy a posi carrier and 3.23 gears. Your '89 is one of those "transition years", meaning it could have one of two kinds of parts in it (axles, in this case), you have to know which you've got in order to get the right posi carrier, and the only way to tell is to take it apart.
What Rusty was trying to say in his not-so-tactful way is that this is a job that requires special tools and a bit of experience to get right. So, your best bet would be to check around for a shop that does gear changes on a regular basis, tell them you want 3.23 gears and a posi, and let them get the parts and do the job.
You can figure on something like $300-$450 for the posi carrier, $180 or so for the gears, about $100 for the "installation parts" like spacers, sleeves, and bearings, and about $150 for labor.
Originally posted by mrt89rs
rustynut,
NOOOO.....
rustynut,
NOOOO.....
Your best investment would be a whole rear from a junkyard, I could pick one up for well under $200 with a posi and 3.23.
Gears alone would cost more than that.
And if you did the modifications listed in your signature then changing the entire rear would be easily accomplished by you.
Car: 89 camaro rs
Transmission: th350
ruztynutz,
i did not get a chance to reply after five7kid did. but he mad it clear to me what it is someone would have to go through just to change the gears and differantial and that was some thing i didn't know when i reply to your post. sorry dude, hehe
I think that i am going to do what you said too. I will buy the rearend off of frind and then put that on i am sure that i can do that myself.
thanks for the help guys
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Pac J
May 17, 2020 10:44 AM
FueledSoul
Sep 29, 2015 08:58 PM
