is this the synchros going bad?
Old Jul 6, 2002 | 07:39 AM
Ziggy89Formula's Avatar
Here's the problem: When I'm driving normally, I hear a little grind everytime I upshift accelerating. But worse is slowing down; I must brake engaged in gear before I can dissengage the clutch and put the trans in neutral when slowing down or coming to a stop. If I dissengage the clutch and put the car in neutral at speed, using the brakes to brake and not the engine, I get a loud noise that sounds more like a metal friction noise than a typical gear "grind". One mechanic told me the synchros were going bad, but I've read that that's rarely the case. It has recently got a new clutch, which two mechanics inspected and is fine.
Any ideas? The car has just under 100,000 miles.
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
dimented24x7
Sep 17, 2015 06:58 AM
gta892000
Sep 16, 2015 12:40 AM
