Did the 89 turbo t/a have a dana 44 rear?
Old Jul 9, 2002 | 12:31 PM
86 sports coupe's Avatar
Car: 86 sports coupe-83 berlinetta
Engine: 5.0 in the sports coupe-350 in the berlinetta
Transmission: 700r4 in the sports coupe-turbo-350 with a 2500 stal in the berlinetta
What gear ratio did they have?
Old Jul 9, 2002 | 02:57 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
I think they all had 9 bolts. Only the Firehawks had the Dana 44's. Not much strength difference between the 9 bolt and Dana 44 anyways though.
Miles
Diff Solutions
www.9bolt.com
Old Jul 9, 2002 | 07:46 PM
JERRYWHO's Avatar
I have a GMPP Dana 44 in my 92 and yes big difference.
Jerry
Old Jul 9, 2002 | 11:22 PM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
92's had 10 bolts.
Since I can't make the picture work, here's the link
http://www.koolmeister.com/hot_rod_article_sm.jpg
Old Jul 10, 2002 | 12:07 AM
JERRYWHO's Avatar
92's had 10 bolts.
True 92's have 10 bolts.
My car ( Non factory ) has a G.M. performance parts dana 44 the same one SLP used in the Firehawks.
To quote Jeff Smith "The word is that this rearend is stronger than a dana 44." The word is Wrong........
The Dana has a 8.5 ring gear a bigger solid mounted pinion, bigger diff all 13 plus styles, bigger 30 spline axles, bigger axle tubes, bigger 1350 rockwell yoke.
That's the reason G.M. sold the rearend in the Performance Parts catalog and not the production 9 bolt.
All the parts are still in stock at G.M. the housing is the only thing out of production.
Jerry
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
86White_T/A305
Aug 17, 2015 12:16 AM
